C2 parts - NCRS Discussion Boards
C2 parts
  • Dan Tewell
    C2 parts
    I need a little help with some part numbers for a 65 L76. The first one is a water pump pulley with the number 3770245CC. Is this the correct pulley for this engine? The next part is an antenna with the number 5045511. This antenna runs but does not go up and down. If this is the right antenna for the car, is there any place to get parts or service it. I know that on the newer(79ish) that you can get the internal cable with the top section attatched to fix this problem. Is this true with this antenna? Thanks in advance.
    • 43221
    Re: C2 parts
    Dan-----
    Water pump pulley GM #3770245 is the correct one for the 1965 L-76 application. It is still available from GM, although the current pulley differs slightly from the originals.
    GM #5045511 is not the part number for any antenna ASSEMBLY that I can find record of. I suspect that this part number is a part number for a not seperately serviced COMPONENT of an antenna assembly or it's a Delco parts system more-or-less "generic" antenna assembly.
    • Dan Tewell
      Re: C2 parts
      Thanks joe, Is there any place on the antenna that I would look for a number? This 5045511 is on the big round part of the antenna (where the cable winds up)
        • 43221
        Re: C2 parts
        Dan------
        If you are talking about an embossed part number on the component that you describe, that's almost certainly a part number for that component only. Usually, IF a part number for the antenna assembly appears on the assembly, it will be on a paper label.
        • Dan Tewell
          Re: C2 parts
          Thanks again Joe. I still believe that this antenna is from a 65. Is there anyone rebuilding these?
            • 43221
            Re: C2 parts
            Dan-----
            It could very well be from a 65. I don't know of a rebuilding source, but I'm sure there is one out there.
              Re: C2 parts
              Dan -
              Call Dale at OEM Glass, (800) 283-2122. Not cheap, but you won't find anyone better (or cheaper).
              • Mike M.
                • May 31, 1974
                • 8385
                Re: C2 parts
                agree with john on the Dale Smith endorsment. mike
