C2: AC heater shut-off switch hiss - NCRS Discussion Boards
  • Dan Pepper
    I just replaced the the brass heater shut-off switch with an "exact" repro from LIC. Also replaced the vacuum hoses with over-the-counter hose to make sure I wouldn't have to take the glove box out again. Problem is, I can hear a vacuum hiss from the switch whenever the car is running. Doesn't matter if the heater knob is in or out, just get a different pitch hiss.
    When I took the old vac hoses out (they looked very original to me), I noticed two small metal in-line butt connectors in the small dia hose. One just a few inches down stream of the vac switch, and another just in front of the water shut-off valve. I figured someone was just trying to make short ends of hose work by butting pieces together. Now in retrospect, these connectors would
    tend to neck-down the inside diameter of the hose. Just wondering if these are supposed to be there to lessen the vac to the valve, and if not having them would cause the hiss I'm hearing - or is the brass valve just funky?
  • Don H.
    • December 1, 1981
    • 1487
    Re: C2: AC heater shut-off switch hiss
    I have had a 64 & 65 w/ac and both did not have any tube like you descibe in the line. Don H.
    • Kenneth S.
      • July 31, 1981
      • 302
      There are no sleeves in the hoses. I bet the valve is defective. You should send it back.
      Ken
      • Dan Pepper
        Just spoke to LIC - they said they'd replace the valve.
        • Geoff C.
          • May 31, 1979
          • 1613
          Sir,
          Original Brass valves can be repaired for less than a buck. I replaced the seal in mine nearly 8 years ago and still performs as specified and no hissing ever.
          DocRebuild
          Save 50 Bucks
