Gas pedal for 57 vette - NCRS Discussion Boards
  • Dan Provost
    Just got my 57, and the gas pedal is missing, the repair job that someone must had attemted involved a bolt with two nuts welded on, fitted into a hinge like bracket bilted through the floor/fire wall. The bolts that were welded into the the u bolt were driven into two holes at the base of the pedal and there were no signs of attachment on the top of the pedal, it just rides against the pivot rod. how was the pedal mounted originally? I see no bolt holes that could have held the original brackrt in, also the bolts that are driven into the rubber at the base of the pedal are just jammed in there, the pedal is going to just fall off again if left this way.
  • Mark S.
    • July 31, 1983
    • 660
    Re: Gas pedal for 57 vette
    There have been some original gas pedals on Ebay lately. You might want to pick up an original and then match the the mounting hardware.
      The metal hinge plate at the bottom of the pedal was attached to the floor pan with two 1/4"-20 bolts through holes in the plate and the floor, with nuts, flat and lock washers on the engine side; shown in the A.I.M. in UPC 6, Sheet 5.0.
      • Dan Provost
        Thanks guys, will look for that replacement.
        • Robert Willis
          They look like the same pedal as a 55 to 57 Passenger car to me. Bob
          • Mark S.
            • July 31, 1983
            • 660
            They do have the same part number as the passenger cars.
