C3 Htr/Defr Actuator Rod Seal - NCRS Discussion Boards
  • Don A.
    • November 1, 1994
    • 7
    The actuator found on the left side wall of my 69 heater/ defrost duct assembly that controls air flow to floor or windshield has a cracked rod seal. This seal is conical and is similar to the seal on the wiper door actuator, only smaller. The AIM does not identify the GM part # for either the actuator or seal. The actuator is stamped Delco Remy, rod has 963 on it and the seal has LD 154 molded into the base. That said, does anyone out there know where I can source a replacement rod seal for this actuator? Thanks
    • 43221
    Re: C3 Htr/Defr Actuator Rod Seal
    Don-----
    I don't know of a source for the actuator seal. It was never available as a seperate part from GM. The actuator assembly, GM #1998955, is discontinued from GM. However, I believe that Dr. Rebuild has a replacement available.
