Thanks everyone for the helpful tips and advice. I want to provide some additional info: I'm working on a '69 427/435 4spd and I did use a one piece Fel Pro oil pan gasket (which is great for both its sealing qualities and ease of installation - comes with these "pins" that hold the gasket on but allow you to bolt up the pan).
The reason I question the rear seal is because the oil appears to only be coming from within the bellhousing and occassionally from between the bellhousing and trans BUT NOT from between the oil pan and bellhousing. Wouldn't a leaking rear seal show signs of leaking oil between the pan and bellhousing? The car has an aftermarket safety bellhousing providing a clear view to the area of the rear main seal. It also doesn't appear to be coming from the back of the intake. The plugs on the back of the block sound like a potential source. Has anyone else ever had the plugs in the back of the block leak?
I've just recently put about 10 miles on the car so there is more oil "evidence" to investigate. The oil is coming out from within the bellhousing (it's an aftermarket blow-proof) from all different places - I suppose because the flywheel is slinging it. The starter is covered with oil and it appears it is coming from where the starter enters the bellhousing. Thanks.
