Horn Relay Ground - NCRS Discussion Boards
Horn Relay Ground
  • Ray C.
    • June 30, 2001
    • 1132
    Horn Relay Ground
    After 1 1/2 years of restoration, I finally started the 65 using the key. I labeled a short black double terminal wire as horn relay ground. Where does this wire terminate for ground?
    Thanks for all your help!!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Horn Relay Ground
    The relay will actually ground on the radiator support on most applications, but there is a ground wire that attaches to the mounting screw. It grounds back to the voltage regulator and a harness ground.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks! Wayne
      After posting on horn relay ground I found wiring information on relays in the 65 shop manual and AIM. The electrical drawing in the shop manual shows a 12 black wire from the ground on the alternator to the top fastener of the voltage regulator, but does not show the jumper from the regulator to the horn relay. In a subsection in the AIM manual the drawing shows the 14 black wire connecting to the horn relay and the jumper then going to the top fastener of the voltage regulator. Any idea of which would be the preferred method.
      Thanks for your help!
      Ray
      Ray Carney
      • William C.
        • May 31, 1975
        • 6037
        The voltage regulator grounds thru it's base, so in a '65 non-air car, the ground attachment at the horn relay grounds the rad support, horn relay and VR all with one wire. The A/C cars mount the VR on the inner fender, so the black wire in the harness goes to the VR nounting bolt to ground the VR
        Bill Clupper #618
        • Wayne W.
          • April 30, 1982
          • 3605
          I just looked at one in the shop and it does have a jumper from the VR to the Relay. It is placed under the same screw that the capicitor on the regulator goes to and over to the base of the relay.
          • Ray C.
            • June 30, 2001
            • 1132
            Thanks for all the help!
            The main ground wire went to the relay and the jumper went to the top of the Volatge regulator.
            Again, Thanks!!
            Ray
            Ray Carney
