Ballast Resistor - NCRS Discussion Boards
Ballast Resistor
  • Michael B.
    Infrequent User
    • August 31, 2001
    • 13
    Ballast Resistor
    Does anyone know if the hole that the Ballast Resistor bolts through on the firewall requires an insert or does the bolt just thread through the fiberglass? The reason I am asking is appears that the hole in my firewall is wallowed out and oversized and I can't seem to get the bolt to snug up like I think it should. Any help would be appreciated.
  • Donald O.
    • May 31, 1990
    • 1586
    what year? *NM*
    • roy braatz
      Re: Ballast Resistor
      All are srewed in to the body glass that I know of.
      • Michael B.
        Infrequent User
        • August 31, 2001
        • 13
        Re: what year?
        1967 L36
        • Mike M.
          • May 31, 1974
          • 8385
          Roy is correct. Its not at all uncommon for the hole in the fiberglass firewall to enlarge after many withdrawl/insertions of the pan head phillips fastner.Rather than glass the hole shut and redrilling, i have inserted a speed nut between the cockpit side of the firewall and the jute backed cardboard firewall insulation. usually the jute keeps the speed nut positioned until you can start the threads of the pan head screw into the speed nut. time consuming but no need to drag out the resin and cloth with its inherent clean up mess. good luck, mike
          • scott gunderson
            just had the same problem on my 63, for a temporary fix,(may leave it) i put a couple of toothpicks in the hole then threaded the bolt in, gave it something to grab on to, then broke off the ends of the toothpicks.
