Grease question - NCRS Discussion Boards
Grease question
  • John A.
    • August 31, 2002
    • 172
    Grease question
    What would be the preferred grease for front wheel bearings? Most all greases have "wheel bearing" on the can... Some have MFG lables -ie GM or Ford etc.... Does the color tell anything about its application? Also, there is a part number on the can... is there a preferred PN for C3 application? What about the synthetics? Thanks...
    • 43221
    Re: Grease question
    John-----
    Use one of these:
    1) Valvoline SynPower Synthetic Grease Product #985 (tube)
    2) GM #1051344 High Temperature Wheel Bearing Grease ("tub" only)
    I use the Valvoline grease for all wheel bearing applications
    • Richard D.
      • December 1, 2002
      • 328
      Re: Grease question
      Joe, would the Valvoline synthetic also be OK to use in the steering box instead of the fluid?
      Rich
        • 43221
        Re: Grease question
        Richard-----
        If by the term "fluid" you are referring to a lubricant of some viscosity less than "140 wt" grease, no 63-82 Corvette ever used such a lubricant. I don't think that 53-62 did, either, but I'm not certain of that.
        I think that the Valvoline #985 could be used for Corvette steering boxes, but I don't use it for that application. I use the Valvoline #985 for wheel bearings, front and rear. I use GM #12377985 for just about everything else. I would use it for the steering box, too, but it so happens that I have a "lifetime+ supply" of the original Corvette steering gear lube, GM #1052084, so I would likely use that for the steering gear if I needed to [none for sale]. I think that the 12377985 is just as good, or better, though.
