C1 Trunk Electrical - NCRS Discussion Boards
C1 Trunk Electrical
  • Dennis A.
    • April 30, 1999
    • 1010
    C1 Trunk Electrical
    The AIM for wiring the tail lights of a 61' shows that there is no grommet in the trunk-to-gas tank panel. Is this an error? Also, is there a clip (#371727) mounted in the center of the lid catch? If so, is it a standard clip with a screw hole and is it bonded under the trunk lip? Details,Details...
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C1 Trunk Electrical
    Dennis - I have never seen a grommet in the place you indicate on a 61/62. The clip you mention, bonded in place. Never seen one out to check for hole. Look at AIM & part numbers for all clips. Bet you will be able to find if that particular clip is used elsewhere on the car - and therefor be able to tell if it had the normal hole. Dennis
