C2 {1966) small block oil leak,intake-block juncti - NCRS Discussion Boards
  • William Ford
    Help!
    need tips on quick and dirty way to stop oil leal from where intake manifold meets back corner of top of block and cylinder head.-prep?sealer type?Don't have time to change intake manifold gasket.
    Many thanks.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C2 {1966) small block oil leak,intake-block ju
    NO QUICK FIXES HERE. CARRY EXTRA OIL TILL YOU HAVE TIME TO REPLACE THE GASKETS AND SEALS. MIKE
      • 43240
      William and Mike-----
      Yup! That's the way it is. Also, when you do get around to replacing the seals, I suggest that you use silicone RTV in place of the rubber end seals. If you apply it carefully and properly it will do a far better job of sealing than the stock-type seals. GM went to this method in the later C3 era for all small blocks.
      I recommend using Permatex Ultra Copper for this application. Make sure that the manifold and block end surfaces are COMPLETELY free from any oil before you apply the sealer. Clean them with Brake Clean solvent before you apply the sealer.
