'61 fan clutch rebuild - NCRS Discussion Boards
  • Bruce G.
    • December 1, 2002
    • 36
    I need my "original" 5 blade fan clutch repaired/rebuilt. It's the only thing holding back completion of under the hood overhaul. I have been told Fred Oliva in FLA is one of the best, but can't find info on him or anyone else qualified to send clutch to. Any help would be greatly appreciated.
  • Karl #35089
    Re: '61 fan clutch rebuild
    The link below is Fred Olivia's site & has further contact info. -k
    Fred Olivia Clutches
    • mikemccagh
      Fred does excellent cosmetic restoration of orig. fan clutches, but when P.V. time rolls around, suggest you use a new GM fan clutch. Would also use the new one once you're thru judging process. good luck, mike
      • John Lokay
        Mike, What is the basis for your recommendation?
        • Mike M.
          • May 31, 1974
          • 8396
          I have seen what a grenading fan blade/ fan clutch assembly does to a radiator and fan shroud and hood. Fred , i believe, removes the seal on the back side of the fan cluch shaft and inserts a viscous material then epoxy's the seal back in place. If your clutch fans have movement when you grab hold of the fan blade(engine off obviously) and force it fore and aft and note play, then i would not consider it a safe fan clutch. Last time i bought the service replacement fan clutch from chevy, they were about 80 bucks. It only takes several minutes to switch back to fred's beautifully restored fan clutch when its flight or duntov judging time. For highway useage or at P.V. time , its just a couple more minutes to replace fred's fan clutch with a much safer GM service replacement fan clutch. good luck, mike
          • Ken Robb
            We had a road tour 67 on the trip to Bowling Green National in 2000 that can show/explain what a re-built fan clutch does to a radiator when it fails. Not a pretty sight. He got a free trip on into BG on a trailer. Like Mike say, use a new GM one for the road.
            • Bruce G.
              • December 1, 2002
              • 36
              Thanks for info on Fred Oliva. Clutch being rebuilt and will get GM replacement for running after September judging
              • Bruce G.
                • December 1, 2002
                • 36
                Mike...Thanks for info on clutch; sent to Fred Oliva for rebuild and I will get GM replacement for running after September flight judging.
                • Bruce G.
                  • December 1, 2002
                  • 36
                  Ken... I will take heed about GM clutch replacement for road running. thanks for input/comments...bruce
