Does anyone know where to find the correct shape/material seals for the upper control arm outer pivot pin seals? This is the pin that has the caster/camber adjustment function. The seals I received with the suspension rebuild kit have a square profile, unlike the flat (tubing-like) seals that were on the car and depicted in the ST-12 (pg 3-12). Some replacements are simple O-rings that don't even work well. Any help would be appreciated.
Denny
Denny
