C1 Front Crossmember Shims - NCRS Discussion Boards
  • Ed T.
    • November 1, 2002
    • 95
    Has anyone used multiple front crossmember shims on a C1 to get correct camber? Thanks...Ed
    • May 31, 1974
    • 8389
    Re: C1 Front Crossmember Shims
    no need for muliple shims if frame and/or front suspension components aren't bent. take chassis to local body shop with good frame straingtening equipment and have them check out its measurements. bgood luck, miike
      The crossmember shims are there to gain increased caster range; the camber adjustment is inside the outer upper cross shaft.
      • Ed T.
        • November 1, 2002
        • 95
        That is what I thought, but at max positive adjustment, the camber on both my front wheels is negative a half a degree. I had heard an extra shim might somehow help, but I wanted to see if anyone else had tried this technique. Back to the drawing board. Thanks...Ed
