C-1 Spare Tire - NCRS Discussion Boards
C-1 Spare Tire
  • Don Ursery
    C-1 Spare Tire
    Has anyone purchased a tire (other than Coker) for a spare on a regular brake '62? I currently have 205-70R-15s but found that to be too thick for spare tire compartment. Any help is greatly appreciated.
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C-1 Spare Tire
    Don... My experience has been that bias reproduction or todays equivilent size radial will not fit correctly in the spare well because the section width is too great. For judging occasions, I have heard that some members have actually reduced the tire pressure enough that the fit would become tolerable... Incredible, but true !!!
    • Mike M.
      • May 31, 1974
      • 8385
      Re: C-1 Spare Tire
      Put four run-flats on your C1,throw away the plywood cover, fill tub with ice and your favorite beverage,take off and have fun.mike
      • Joe Pennington
        Re: C-1 Spare Tire
        I was lucky and found a new 6.40/15 (no typo on size) at a used tire place. I would guess it was mfg'd late 70's but stored inside with no dry rot.Perfect fit in my 56's spare tire well ( after I removed all the liquid pork chops). I also found a new 195/75-15 at the same place that I use as a spare in my mid year.
        • Tom Murphy 38312
          NCRS Publications
          I'm afraid I can't offer anything but another question on this. I replaced the tires on my '60 this week with Coker radials and kept one of the 670x15s for a spare. It doesn't fit either! -- even though that's supposed to be the original size. Maybe the spare is meant to be flat?
            Re: NCRS Publications
            When I put radials on my '57, I used one of my repro BFG Silvertown bias-ply 6.70-15 "judging" tires as my spare - the diameter fit fine, but it did raise the cover to about 1/4" above flush with the trunk floor.
            • Don Ursery
              Re: C-1 Spare Tire
              Thanks everyone. I did find a 185-70R-15 at Sears (Washington State). Had to order it, will try fit when it comes in. Again, thanks for all the inputs.
