61' engine install update - NCRS Discussion Boards
  • Phil Fischer
    Thx to all who provided advice on my engine/trans alignment problem. I removed the pressure plate bolts and was able to slide the assembly back far enough to see what the trans input shaft was doing, I was then able to wiggle the engine around and it slid into the pilot bearing as I hoped. The NCRS once again comes through in a pinch.....Thx again Phil
