'60 Metal in Oil - NCRS Discussion Boards
'60 Metal in Oil
  • Ted L.
    • May 31, 1999
    • 101
    '60 Metal in Oil
    I've just changed the oil and filter for the first time after an engine rebuild. Got about 300 miles on the car. It runs good and holds good oil pressure - about 60 pounds at revs and 45 at idle. I examined the oil visually and it appeared to contain fine metal particles in the bottom of the drain pan. It looks like the metal you'd see in metallic paint. I pulled a magnet through it and sure enough, there is a coating of fine metal on the magnet. I cut the filter apart and the paper element has the same fine particles, nothing big enough to call a chip of metal. I took the filter to the shop where I had the engine rebuilt (overbored, new pistons, crank turned, all new bearings and seals etc.). The technican was not alarmed, he says it's not uncommon to find metal in the first oil change and it will decrease with subsequent changes. He advises me to drive it and check again after the next oil change. Should I be worried? Is there something I should be doing in the meantime?
    Ted #32350
  • Mike M.
    • May 31, 1974
    • 8391
    Re: '60 Metal in Oil
    fine metallic particles not uncommon on fresh rebuilt engine or a new one for that matter. Just changed the oil in my new pickup at l000miles. The magnetic oilpan drain plug had about 1/`16 inch of fine metalic debris attached.Drive it and have fun.mike
    • Bob Simard
      Drive it and have fun, BUT get a magnetic drain plug.
      • Clem Z.
        • January 1, 2006
        • 9427
        check the play in the thrust bearing because i have seen this metalic flakes and the thrust face of the rear main was wearing.
        • Philip Whitaker Member# 2024
          Ted,
          Three yaers ago I put an Edlbrock hi torque cam and lifter set in a 454 to increase my trucks towing performance. When I changed the oil after a few hundred miles,it looked like it had ultra-fine metal particles in it. Almost a pearl-like appearance. Like you, I tore apart the filter. A friend that built and raced stock cars told me not to worry, that this was common on new engines. Well, he was right. The next oil change everything looked normal. I put about 30 thousand miles on the truck after that before trading it for one of the new GM trucks with the Vortec 8.1. Never a problem with the old 454. I'd change the oil and see if the metal hasn't disappeared.
          Phil
