Can someone give me the nominal resistance range of the rheostat in the sender. I'm building a circuit to test fuel gages. Thanks
Fuel Tank sender
Re: Fuel Tank sender
Radio Shack has a 0-100 ohm variable potentiometer (a/k/a volume control) for five bucks that makes a great diagnostic substitute for a fuel gauge sending unit; if they don't have one hanging on the wall, they can order it from the catalog. Also works great for determining additional resistance required to make a temp gauge read correctly, although the gauge will no longer be linear across its range with "calibration" resistance added.- Top
Re: 0 ohms empty, 90 ohms full
OK I give up, how do you measure the resistance on the fuel gage sender? I know it should be 0 to 90 ohm but does it have to be measured with a John Fluke meter that I do not have? My 24 gallon tank has never worked right so I peened the bad connection (resistance read zero almost all the time) on the wire connection on the sender. I measured mine with a standard (cheep) meter and could barely see any change from one end to the other, like 1 ohm to about 3 ohms but the gage started working, holding the sender in my hand with the sender hooked up to the gage. The gage read about 1/8 tank on the bottom and barely above full with the float at the full position. Any help is appreciated.
Gene
fuelie1962@aol.com- Top
