C1 Rad. Support Seals - NCRS Discussion Boards
  • Peter Cipriani
    Did 1961 vettes use 3 piece rad. seal sets or 5 piece?? Also CC sells a 3piece set for the bottom and 2 piece for the side labeled high performance??? My question is this, do I need side rad. seals for a 61 270hp and should their be holes in the rad. cradle to clip the side seals in place??
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C1 Rad. Support Seals
    Peter... This is kind of a backward way to answer you question - but if your car originally had the 2 vertical side seals, you would have 3 holes, each side, and they would be drilled, not punched, in the sides of the radiator support.
    • Loren L.
      • April 30, 1976
      • 4104
      The '62 AIM calls out the side seals as a running change in 1962.
      • Dennis C.
        • January 1, 1984
        • 2409
        Thanks Loren, I just can't ever seem to have an NCRS JM by my side when I need it.
