66 Brake Calipers - NCRS Discussion Boards
66 Brake Calipers
  • John F.
    • July 31, 1999
    • 105
    66 Brake Calipers
    I'm reconditioning the brake calipers on my 66coupe, and I note that the judging manual specifies semi-gloss black paint for the calipers. Does this require a specialty paint, or will any semi gloss black do the trick? Thanks
    • 43221
    Re: 66 Brake Calipers
    John-----
    The original paint used on these calipers was really a semi-flat black rather than a semi-gloss (I have many NOS caliper halves that I've inspected for this [none for sale]). However, if I were you I would use VHT semi-gloss black caliper paint. This is the closest to original "sheen" that you can get in this paint. This is a special high heat paint that is RELATIVELY impervious to chemical attack. Glycol-ester brake fluid (DOT 3 and 4) which often gets "spilled" on calipers during bleeding operations will instantly remove most paint. This paint will last awhile exposed to it, though.
    • John F.
      • July 31, 1999
      • 105
      Joe - as usual, thanks for the quick response. Any suggestions as to a supplier for the VHT semi gloss?
        Most speed shops carry the VHT line, as do Summit and Jeg's.
          • 43221
          John and John----
          Yes, but you want to make sure that you get the special VHT paint for brake calipers. Not all places that carry VHT carry these. Vic Hubbard Speed and Marine in Hayward, CA is one that I know does----that's where I get mine.
          • Dave S.
            • August 31, 1992
            • 2925
            John,
            I have had good luck mixing Rust Oleum gloss with Rust Oleum flat to make a semi gloss. I use about 1/3 gloss with 2/3 flat. It makes a paint that will last for a long time and will stand up to DOT 3 and DOT 4 brake fluids. Apply with a large artist brush and clean tha machined surfaces after it dries. You can buy Rust Oleum in any hardware store.
            • John F.
              • July 31, 1999
              • 105
              Great suggestion Dave - thanks
              John
