On my 68 327 L79 on the passenger side FRAME motor mount extension to which the actual motor mount is bolted, there is a very large ground cable approximately the thickness of a finger, bolted to the frame.
I am ASSUMING the other end goes to the motor or starter to make a ground but don't know exactly where it should be attached.
Can anyone shed any light on where it should be attached. I had made a written note about the frame location but somehow (many years ago) forgot to make note of where the other end goes.
Thank you in advance for any help.
Kurt # 26406
Kurt # 26406
