C2..1965 Grille attachment - NCRS Discussion Boards
  • Dave B.
    • April 30, 1984
    • 248
    I am puzzled about the correct lower attachment for the 1965 grille. Does the grille attach in the center to the lower valence with a J-nut in a flush attachment as shown in the parts catalog, or is there a protrusion type attachment, similar to the way the '63 and'64's attach? I am hearing both.
    Thanks...Dave
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2..1965 Grille attachment
    The fiber glass lower valance panel on 64 and back is different from 65 on. 64's have two ears in the corners and more of them along bottom than do 65. You should have center fiberglass tab mounting only on your 65. Brace type rod and grill sheet metal bracket attach with phillips screw in to j-clip.
