Tin-Zinc Electroplating - NCRS Discussion Boards
  • Joe Maulsby
    Is the Eastwood tin-zinc electroplating system what I need to plate nuts and bolts for my 1960? Or is there a better product for this? I am only going to plate a few nuts and bolts at a time, not a "large scale" operation.
  • Roger S.
    • May 31, 2003
    • 262
    Re: Tin-Zinc Electroplating
    I purchase the Caswell system instead of the Eastwood system. Have not used it yet. Several posters had used the Caswell products and were satisfied with it. I liked the power transformer in the Caswell system over the batteries in the Eastwood.
    Roger
    • Peter K.
      • January 1, 1999
      • 117
      I have both the Caswell system as well as the Eastwood system, the Caswell produces a better finish. It also will allow you to plate larger parts such as your hood hinges, hood and door strickers, etc. I also found it easier to buy new nuts and bolts rather than replating.
      • Dan Tewell
        Where can I get some information on the Caswell system?
        • Peter K.
          • January 1, 1999
          • 117
          www.caswellplating.com, Under the plating category look for the Copy-cad and zinc plating kit, I bought the 2 gallon kit, it's worth the money. Good Luck
