1962 Heater Box - NCRS Discussion Boards
1962 Heater Box
  • Terry D.
    • May 31, 1987
    • 2691
    1962 Heater Box
    Two Questions really.
    One- I have an assembly manual, but it doesn't always show how things are put together. Is there any other books I should have that will show a little more detail.? Which brings me to question two- I trying to put heater box back together, was all apart in pieces when I got the car. I got new studs, core mountings screws, gaskets, etc. The studs have retainers on them,do they just hold the studs to heater box? If not what is the order of assembly? I assume the thick gasket goes between door housing and metal plate, then plate to heater housing, is this correct? Thanks in advance people!
  • John S.
    • July 31, 1990
    • 292
    Re: 1962 Heater Box
    Terry I'll take a stab at this. Been some time since I have had one out. The stud's go threw the fiberglass heater box and those little retainer's hold them to the box. Then your gasket goes on the box, now put the metal plate on and then the lage gasket will fit against the fiberglass firewall of the car. Now put your lock washer's on and nut's. The bolts after tightened will extend about 3/4 to 1 in. that's the way they were. Now putting the fresh air box on the factory put alot of dum dum around where it mount's so when you sqrew it on with the sheet metal sqrew's that have 1/4 in socket head the dum dum would squeeze out and look meesy.Hope this help's. Open for any correction on this guy's. john
    • Chuck L.
      • July 31, 1996
      • 260
      Re: 1962 Heater Box
      The only other books you might want to check out are Noland Adam's Corvette Restoration and Technical Guide-Vol. 1 and the 1962 Servicing Manual (ST-10) They have a lot of detail and photos. Available from the NCRS Store. Chuck
      Chuck Lyman
      Kansas City Chapter
