C1 59 Vette Delco cap D308R ??? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 941
    Need a delco cap for judging, what does the R mean and will it pass or is it wrong? D308R? Help, Thank you
  • Dave S.
    • August 31, 1992
    • 2925
    Re: C1 59 Vette Delco cap D308R ???
    Bill,
    I assume you have a 230 HP car. If so the correct cap is a Delco Remy, D-308, black, single window, cap with PATENT PENDING, No R embossed on the top. Any Delco D-308 cap will functionally work but only the PATENT PENDING, no R cap will pass muster on the judging field. Any other marking(s) will take some point deduction on origionality. If you have anything but a 230 HP car with the 891 dual point distributor you will need a D-305 cap which has no external markings at all.
      • 43221
      Bill-----
      I believe that the "R" refers to some resistive component or compatibility of the cap, although others dispute this. The "R" first appeared on these caps at the same time that resistor spark plugs bean appearing on the cars (about 1969). After they appeared, they were the only SERVICE part that was produced for all applications of the particular Delco number. In other words, after about 1969, if you needed a Delco D-309, all you could get was a D-309R which SERVICED both D-309 and D-309R applications.
      • William B.
        • April 30, 1975
        • 941
        Thank you, i was looking for a cap and found a D308R. Now i know i need a D308
        • Dave S.
          • August 31, 1992
          • 2925
          Bill,
          You not only need a D-308 non "R" cap but to be correct you need a Patent Pending style. Some more plentiful D-308's have a Patent Number in lieu of Patent Pending but do lack the R.
          • William B.
            • April 30, 1975
            • 941
            Looking down on the top of the cap, does it say "D308" or just delco remy patent pending? thanks Bill
            • Dave S.
              • August 31, 1992
              • 2925
              Bill,
              D-308 is a Delco number and came w/ different markings on the top. You will see markings as follows however all Delco caps will have Delco Remy embossed on the top of the cap. In addition it will have:
              Patent Pending
              Patent Pending R
              Patent Number(it is 7 digits ending in 047)
              Patent Number R
              Costs will vary greatly with different markings.
              • William B.
                • April 30, 1975
                • 941
                Thanks Dave, I'm learning
