1965 BB Rad Supt Seal - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    I've run across a "Technical Information Bulletin" dated 7/16/65 that states that 1965 L78s PRIOR to VIN #16736 may need part # 3827365 - called out as a 1 1/2' long rubber seal - installed on the radiator support to stop "hood flutter" or "hood rapping". My copy of the AIM does NOT seem to refer to this and neither does my copy of the Judging Guide. Is it true or false? The implication is that effective with #16736, the seals were installed at St Louis.
  • Mike M.
    • May 31, 1974
    • 8391
    Re: 1965 BB Rad Supt Seal
    loren: I have an orig seal off of vin about 17500, and my two 396's both have the seal( they are Vin 18503 AND vin 22137. the seal was unavailable and unique when i researched this item back in the mid-80's. The judging manual, on page 131, discusses the seaL. hollar if i can be of further help. regards, mike
    • Geoff C.
      • May 31, 1979
      • 1613
      How about a picture Mike? *NM*
        • 43222
        Loren-----
        GM #3827365 is a piece that would have been originally released in late 1962 to early 1963. It was never available from GM as a SERVICE item.
        It may have been a bulk item used only in PRODUCTION and cut-to-size, as required.
        • Bill W.
          • March 1, 1980
          • 2000
          I looked at my old photos of 17346 . it had a piece of squared rubber hanging on by a thread on top of the core support. all that is left of it now is a trace of yellow weatherstrip glue .the glue is on the front upper section. Bill
          • Mike M.
            • May 31, 1974
            • 8391
            Re: How about a picture Mike?
            will try and find the seal, photo it and post it later.mike
              The Doc's catalog shows this seal on page 28, item "B", #1274396.
              • Loren L.
                • April 30, 1976
                • 4104
                Mike, I must have an old JG because
                the only seals I find on 131 are for the clutch rod and clutch fork.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  In 3rd edition it's on pg 119, 3rd line from top
                  This is in Chassis secton 5 (Engine Cooling System); Shrouds and Seals / Big Block. One of these days I'm gonna have to ante up for the latest edition.
