C3 Intake Manifold paint - NCRS Discussion Boards
  • Steve King
    Is there a gm part number for 1980 intake manifold paint? If not what brand and color should I use?
    Steve
    • 43221
    Re: C3 Intake Manifold paint
    Steve-----
    The curent GM part number for 11 oz aerosol cans of the CORPORATE BLUE paint used for 1980 Corvette engines is GM #12346300.
    • Steve King
      Joe,
      The NCRS Corvette Technical Information Manual & Judging Guide says on page 80; the manifold and thermostat outlet was painted with a dull aluminum paint. Not blue.
      Steve
        • 43221
        Steve------
        You are correct and I mis-spoke. I forgot that all 1980 Corvettes used an aluminum intake manifold. If you want to paint your heads, block, or water pump, use the paint I mentioned, but don't use it for the intake manifold.
        The silver paint which was/is available from GM, I have been told is too bright to simulate the original paint. I will have to defer to someone else who has experience using the various aftermarket aluminum paints. I'm sure that there must be one or more out there that will duplicate the original sheen.
