Bonding Adhesive - NCRS Discussion Boards
Bonding Adhesive
  • Robert L.
    • March 31, 1975
    • 6
    Bonding Adhesive
    Getting ready to glue a top surround onto a '63 Coupe.I'm trying to find an adhesive that will give me/us the biggest working time window.Also, any tips that might help.Have used Evercoat's 870 for smaller jobs with excellent results but it seems to go off fairly quickly.Thanks very much!
  • John A.
    • August 31, 2002
    • 172
    Re: Bonding Adhesive
    Bob,
    I recently used bonding adhesive from The Corvette Image... It was recommended to me and I was real pleased with the results. Has a slow set time, black in color, and hi fiber content.
    • Dan Tewell
      Bob, it depends on what your surround is made of. If it's made of SMC, then I would reccomend Evercoat's SMC bonding adhesive. You can slow the kick off by refrigerating both the adhesive and the cream hardner. If the surround is FRP, then you could use the adhesive from The Corvette Image. The SMC adhesive works with both SMC and FRP.
      • Craig S.
        • June 30, 1997
        • 2471
        Bob - you may want to give LORD corporations FUSOR line a try, these products are epoxy two part system, but with working characteristics similar to polyester based products. They have strength advantage, allow working time, and also bond dissimalar materials well....Craig
