1967 corvette ball joints. - NCRS Discussion Boards
  • August M. Heilig
    Upon dis-assembly of our 1967 corvette front suspension,
    we damaged a couple of the rubber boots for the ball joints. The ball joints
    are the original riveted in great shape,(except for the torn rubber boots.)
    Can these boots be replaced? Or are the ball joints now junk? If so where can
    we get the original style ball joints?
    Thank You,
    August M. Heilig.
    • 43222
    Re: 1967 corvette ball joints.
    August-----
    The original style boots on GM ball joints are not replaceable. Even if you could replace them, the boots for these joints were never available in SERVICE from GM or anyone else of which I am aware.
    Original-style GM ball joints are getting to be difficult to find. They often sell for very high prices on eBay.
    I hope that when you removed the ball joints you didn't use a "pickle-fork" type tool. This type of tool should only be used if one is going to replace the ball joints and doesn't really care what happens to the old ones. I prefer a press-type tool whenever ball joints are removed.
    • Mike M.
      • May 31, 1974
      • 8391
      agree with joe that rubber seals were not available and generic ball joint seals dissimiliar from orig ones. Seem to recall seeing similar seals in junkyards on GM pass cars of late 50s and 60s. If you do find junkyard seals, follow joes advice on removal from A-arms. good luck, mike
      • Franz E.
        • March 1, 1997
        • 96
