C1 Wheel Balance - NCRS Discussion Boards
C1 Wheel Balance
  • Steve Westphal
    C1 Wheel Balance
    Can the original wheels with Coker radials be balanced with the wheel weights on the back of the wheels on my '56
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C1 Wheel Balance
    Steve. Yes, but with some compromise on exact perfect balance. Doubt you or I will ever notice the difference. Best, DC
    • Lonnie Johnson
      Rear wheels, no problem, you can't detect. Front wheels, could be problematic. It really depends on the amount of weight necessary. If a lot is required to balance the front tires, I would strongly suggest splitting the amount between inside and outside on the front wheels.
      • Mike M.
        • May 31, 1974
        • 8383
        you could balance wheels inner and outer with adhesive backed weights that would be hidden by the hubcaps. just hope the judges don't ask for hubcap removal and use orig type Ounce designated lead weights for the spare. ALWAYS FUN TO PULL ON OVER ON THE JUDGES, ESPECIALLY SO IF YOUR C1 IS A 61-62 VET AS THAT TEAM LEADER DOESN'T HAVE A CLUE. GOOD LUCK, MIKE
        • Calvin M.
          • August 31, 2000
          • 117
          Hi Steve -
          I have the original wheels with Cokers on my '57, and they're balanced on the back. Works fine.
          Cal
          • Dave Christensen
            I just put Dayton WW radials on my 56 with stick on weights on the back. The balance is fine and the radials are a BIG improvement over the bias ply tires! I am sorry that I waited so long to switch.
            • Dennis C.
              • January 1, 1984
              • 2409
              So how do you think you got the nickname Mikie "Bogus" McCagh ???
