C2 - Z06 Brake Pedal Rubber Pad - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Your opinion, please. Would a 1963 Z06 optioned Corvette automobile be equipped with a brake pedal pad with or without the Power Brake designation? Thanks, Dennis
  • Geoff C.
    • May 31, 1979
    • 1613
    Power Only
    I have never seen that specific Kelsey-Hayes master cylinder, that was not mounted to a Moraine PB booster. Does that mean St Louis also used the usual PB rubber pedal pad with a PB logo - I cannot say so with specificity.
    Geoffrey Coenen
    • Mike M.
      • May 31, 1974
      • 8389
      Re: C2 - Z06 Brake Pedal Rubber Pad
      dipstick: my 28k mile ZO6 has Power brake rubber pad with enough wear on the right side of the pad that leads me to believe its the original.What'd you do, buy another ZO6?
        • 15678
        Sheet 2.00 Sect Z06 of the '63 AIM contains the following note:
        "Cylinder attaching parts, hose, brake pedal, cover hose clamps, tee & brace asm - dash same as RPO J-50.
        There appears to be an obvious misplacement of a comma i.e. "...brake pedal, cover hose..." should be "...brake pedal cover, hose..."
        • Dennis C.
          • January 1, 1984
          • 2409
          Thanks Guys... I've been wondering about that issue since 1985. The only thing I did figure out is that they certainly didn't feel like power brakes.
          • Franz E.
            • March 1, 1997
            • 96
            • David Van Weele
              Hi Franz
              My car has always had the Power Brake pedal designation from day one. Dennis the brakes are not hard after they are warmed up. I drive the first half mile with my foot lightly on the brakes to generated some heat. They work a lot better when warm.
              Dave
              • Dennis C.
                • January 1, 1984
                • 2409
                I sincerely express my thanks to you "posters" for your help on this particular issue. Not many players out there that can respond with authority to this type of question.
