Convertible Top Weatherstrip - NCRS Discussion Boards
  • Mark
    I am about to tackle replacement of my 64's soft top. Is it necessary to replace the weatherstripping at the same time? Would there be a lot of duplicated effort if the weatherstripping was left to another time? Does the Al Knoch video cover replacement of the weatherstripping, or only the soft top itself?
    Thanks as always for your thoughts.
    Mark
  • Gary Schisler
    Re: Convertible Top Weatherstrip
    Replacing a top is a separate operation from weatherstrip replacement. I would think that the condition of your WS would be the detereming factor in whether or not you wanted to replace the WS or not. I did my 66 WS on the car with very little difficulty. All I did was remove and replace, one at a time. That way, I did not have left over parts and didn't have to worry about which screw went where. I do not think that it would have been easier with the top off. I had a small piece of WS at the back of the top that had rusted the inner metal support so badly that I wound up drilling an tapping the screw hole. The rubber was bonded to this small metal tab and it had rusted to dust. This was a relatively easy task.
    • Gary Schisler
