L-79 fan belt - NCRS Discussion Boards
L-79 fan belt
  • Tom Merkel
    L-79 fan belt
    Where would I find an exact fit, replacement fan belt for a '67 L-79?
    The small one, running crank-to-H2O pump only.
    Thanks.
    Tom
  • Gary B.
    • February 1, 1997
    • 7029
    L-79 fan belt; Have you checked with Quanta?
    Tom,
    Have you checked with Quanta Products? I have the impression that they are one of the better supplies of correct belts, but I can't confirm this based on my own experience. Please let me know what you find out, since I will need such a belt for my '66 L79 in the near fture.
    Gary
    • Gary S.
      • July 31, 1992
      • 1632
      Re: L-79 fan belt
      As Gary B. states, Quanta makes a great repro unit that passes inspection well. If you are looking for a replacement, I have had luck with Gates belts at the local auto parts stores. One of my Gates belts was a tad short so I went up 1/2". I believe the discrepencie is due to the fact that the new Gates belt is about 1/16" wider than the original and sits a bit higher in the pulley.
      Gary
      • Donald O.
        • May 31, 1990
        • 1591
        Re: L-79 fan belt
        Gary,
        Do you remember the Gates p/n ?
        Don
        • Brian McHale
          Re: L-79 fan belt
          I would go the Quanta route myself. Use Quanta direct, as some vendors (Long Island Corvette Supply) use a 1 size fits all aproach.
            • 43236
            Re: L-79 fan belt
            Tom------
            The original belt was likely GM #3837810. This was a 3/8" wide belt of 34-3/8". Except for reproduction, this might be a very hard width/length to find today. Since this belt's length is critical, you must use a proper fitting belt.
            The GM replacement belt for your application is a 7/16" wide belt of 35.0" length. The wider SERVICE belts require a slightly longer length. The one you need is GM #9433722 which you can purchase for a GM list price of $13.44.
