C3 Flywheel Dowel Pins - NCRS Discussion Boards
  • Bob Unkel
    Putting back together a 73 with a 79 350. Flywheel did not have dowel pin installed into crank upon disassembly. Hole in crank is smaller than one in flywheel. Clutch is 11 inch. Would appreciate suggestions on how to resolve. IE: Drill it out and ream to 1/2"? What was standard? Any help would be appreciated.
    • 43236
    Re: C3 Flywheel Dowel Pins
    Bob-----
    Your problem is easy to resolve. Most Chevrolet V-8s did not use crankshaft dowel pins. The exceptions were early 265/283s, 400 cid small blocks, and 454 big blocks. The 350 cid engines did not.
    • Bob Unkel
      Thanks Joe, as ususal you are a wealth of information. Your efforts are greatly appreciated. Bob Unkel 36121
