Loose Midyear Door Hinges - NCRS Discussion Boards
  • Michael H.
    • July 31, 1998
    • 180
    The driver side door on my 63 is sagging and wobbling a little despite new bushings and pins. The bolts on the door and jamb are tight as I can get them and I still see no improvement. A body shop technician suggested the rivets are loose and need to be "tightened". Anybody out there have any suggestions on "tightening" the rivets?
  • David D.
    • 330
    Re: Loose Midyear Door Hinges
    Mike, Oversize outside diameter bushings with standard inside diameter for the hinge pin are available. Most auto parts stores carry them. Dave
    • Donald O.
      • May 31, 1990
      • 1591
      Mike,
      He could be right. With trhe door open look down past the hinges and you will see the flat heads of the rivets. Now lift the door up & down. Do the rivets wiggle? Are the INNER hinge attaching bolts tight?
      • David D.
        • 330
        Mike, I re-read your post. I may have mis-interpreted what you were asking. If the rivets you are talking about, are the ones that hold the outer door panel, to the inner panel, between the upper and lower hinges on the door itself, not the hinges. I remember reading a fix, either here, or on another forum. They drilled another hole next to the loose rivets and re-riveted the panels from the outside. They then removed the original rivets and filled the holes. Then
        the rivet heads were filled in and ground down to make it look like the original rivet head. Maybe someone else remembers reading it, and can give more info. Dave
        • Michael H.
          • July 31, 1998
          • 180
          You can definitely see some slop in the rivets. Any suggestions on how to "tighten" the rivets? The only procedure I could think of would be to try and hold a body dolly (or something similar)on the inside of the rivet and strike the head of the rivet with a ball peen hammer.
          • Scott Marzahl
            I recall that fix was to drill out the old rivet and use an oversize head blind rivet (pop rivet) and then fill the head and make it look kind of like an original rivet.
            Accessing the original rivet can be done with the window out of the door. You can reach in far enough, I just did it for my '67, drilled out the old rivet, inserted a new one, held a bucking bar against the rivet and used a rivet gun against the head.
            • Dennis C.
              NCRS Past Judging Chairman
              • January 1, 1984
              • 2409
              Give this a little thought. Get some 1/4-20 carriage bolts about an inch long, lose the rivet, grind the head on the carriage bolt to appear as the original rivet, install and tighten. Worked really well for me on a couple mid years.
