CE Oil Pan Removal - NCRS Discussion Boards
CE Oil Pan Removal
  • don justham
    CE Oil Pan Removal
    On a 1970 small block do I need to remove part of the steering linkage to drop the oil pan or is their an easier way to do it? Thanks in advance for your help.
    • 43240
    Re: CE Oil Pan Removal
    don-----
    You need to lower the steering relay rod to remove the pan. This can be done at either end, by lowering the idler arm or seperating the relay rod from the pitman arm or p/s control valve.
