C2: Touch-up Paint & Prep Question - NCRS Discussion Boards
  • Dan Pepper
    Three Questions:
    I've purchased a quart of ermine white in DuPont's current replacement product for laquer to use for touching-up small chips and dings in the original paint. Will I need to use hardener mixed in for these small areas?
    Also, the windshield grilles on my '66 were chromed by the 3rd owner back in '73. I'd like to paint them - so how should I prep (treat? strip? blast?) the chrome before paining?
    Can anyone suggest a mfg that'd still make gloss dark green (code 430) interior paint for '66? I pinged one paint company mentioned here on the board that makes spray bombs, and they said they could only mix the paint if I sent them a sample to match. Any resources for the right color in the correct formula without going through thd matching process?
  • Dave B.
    • April 30, 1984
    • 248
    Re: C2: Touch-up Paint & Prep Question
    Dan,
    In answer to your third question, you might contact Kris at Tower Paint & Decorating, Inc., P.O. Box 2345 Oshkosh, WI 54903-2345, (800) 779-6520.
    • Karl #35089
      Dan: You indicate that you bought "DuPont's current replacement product for laquer"... If that means you just bought modern-day acrylic lacqer, then no you don't need anything other than lacquer thinner to thin it to the desired viscosity before use. Lacquer is not catalyzed. If you bought something other than lacquer, then I would certainly recommend you buy the lacquer to touch up your original lacquer. Why contaminate your original finish by using a different system to no advantage?
      -Karl
