70 headlight switch removal - NCRS Discussion Boards
  • Jeff A.
    • December 1, 2001
    • 95
    How do you get the knob and shaft off the switch so that the dash pad can be removed? Is there a release or something which allows the shaft and knob to pull outtowards the interior and lets the switch body go towards the firewall. Yeah I've checked the archives.
    • 11649
    Re: 70 headlight switch removal
    There's a release on the back of the switch that lets you pull it out. I think it takes about 2.5 Acts of God to get at it, but it "can" be done.
    Best of luck.
    Patrick
    • Geoff C.
      • May 31, 1979
      • 1613
      • Zachary K.
        • March 1, 1986
        • 162
        Jeff, both Partick and Geoffrey have given you correct information. But looking at your question, you pose the question to remove the switch from the dash so the dash pad can be removed. Actually, if you just remove the wire harness at the switch the dash pad and switch can be removed together.
        Like Patrick mentioned after depressing the button pulling the knob out may take a few tries.
        What,if I may ask are you trying to repair or replace?
        1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
        1969 L71 LeMans Blue, Bright Blue Convertible
        1970 L46 Monza Red, Light Saddle Convertible - Duntov
        1976 L82 Classic White, Firethorn
        2013 LS7 Black, Ebony, Convertible
        Moved on -
        2006 LS2 Black, Ebony, Convertible
