I recently changed the blower motor and heater core on my 69. When I was testing to be sure everything worked on reassembly, I discovered that my windshield wipers no longer worked. I don't know whether they were working before I changed the blower motor because I haven't used them in several months. They were working the last time I used them.
When I hit the wiper switch I get a clicking in the relay, but the wiper door doesn't open and the wipers don't work. If I use the vacuum switch below the steering wheel to open the door, the wipers still don't work. The center knob below the steering wheel that cuts power to the wipers is open.
The ground that the wiper motor shares with the blower motor is connected and the blower motor works fine. I've tested the connections with a test light, and the yellow and green wires going into the wiper motor three connector both have current. The light blue does not. The two prong connector with the yellow and dark blue wire is not connected to anything, although the yellow wire has current. The washer was removed before I bought the car and I suspect these are supposed to go to that, although it is impossible to tell for sure from the wiring diagram.
I think I may have some kind of ground problem because I got a small spark when the metal centerpiece of the dash rested against the shifter knob. The problem is that the ground wires seem to be connected.
I'm running out of things to try. I don't seem to have disconnected any of the wires when under the dashboard. Is there anywhere that describes how the system works to help troubleshooting or are there common problems with these systems that I should check? Any suggestions would be greatly appreciated.
