68 Lower Radiator Baffle - NCRS Discussion Boards
  • Mike Baker
    I'm confused again.
    Did this part exist only on the small block cars with aluminum radiators and Metal shrouds?
    It looks to me like the BB fan shroud would have eliminated the need for this part.
    Thank you.
    • 43221
    Re: 68 Lower Radiator Baffle
    Mike------
    Yes, the GM #3919755 lower baffle was used only with the small block aluminum radiator and circular steel fan shroud. It was not used with plastic fan shrouds used with small block (THM and/or A/C) or big block applications.
    • Mike Baker
      Thanks Joe,
      There is one on Ebay that looks like its in good shape. Since I had not been able to figure out conclusively if I was missing the part or not, I figured I'd ask before it went away.
      Thanks again
      Mike
      • John L.
        • November 1, 1993
        • 74
        Mike,
        If you need the part, check Corvette Central, I believe they have a repro.
        John........
        • Mike Baker
          I don't need it but, thanks for the information.
          Mke
