69 tri power mounting ? & rear valance - NCRS Discussion Boards
  • kelly theaker
    Q#1 are there any washers used on the tri carb mounting base studs ?. to protect the aluminum base of the carbs
    Q#2 the rear exhaust valance used a rivet and nut as an attatchment for the rear exh valance the ? is . did the head of the rivet get painted or was it installed at a later assembly point. thanks for the input
  • Dan M.
    • November 1, 2000
    • 48
    Re: 69 tri power mounting ? & rear valance
    To my knowledge the original installation did not use washers on the 10 studs and or under the head of the two bolts; which are used under the fuel lines.
    Dan Morlang
      • 43221
      Dan and Kelley------
      Yes, the carb mounting nuts or bolts originally used no washers. A lot got added later, though
      The rear lower (exhaust) panel was not attached by rivets. It was attached by bolts and nuts. The heads of the upper bolts (more-or-less hidden by the bumper)were not painted as the panel was installed already painted.
      • Mike M.
        • May 31, 1974
        • 8383
        agree with dan and joe re Q#1--no flat washers on carb attaching nuts for the 67-69 tripower carbs. Wouldn't have been a bad idea to use them but i guess the bean counters at GM in the late 60's didn't want to spend the extra one or two mills it would have cost. mike
        • kelly theaker
          thanks for the carb data, the question was the rear exhaust panel is held on by bolts but the nut plates were riveted on the rear quarter section and were they , meaning the nutplates riveted on the body then painted or were they riveted on after the body paint process ? so did the rivet heads get a coat of paint and primer
          • Wayne W.
            • April 30, 1982
            • 3605
            They would have been installed before the body was assembled, so if anything got paint they would too.
