timing & dwell for 283 230hp. - NCRS Discussion Boards
  • Don Izzo
    Can someone give me the specs for dwell angle (single point distributor) and timing for my 1960? I see in the service manuel that timing is 12 Degrees advanced and dwell is 28-32degrees. Are these numbers correct? is the timing 12 degrees btdc or after? My mechanic said 12 degrees seem wrong. He thought 4 degrees btdc was more appropriate for a small block chevy. Thanks!
    Don
  • William C.
    • May 31, 1975
    • 6037
    Re: timing & dwell for 283 230hp.
    28-32 degrees is correct 12 degrees is also reasonable for this engine/distributor combo. The factory actually allows 8-14 as a range, looking at performance vs detonation "ping" work toward the high end unless you encounter detonation. Your mechanic is too young to remember a "real" smallblock from the pre-smog era.
    Bill Clupper #618
    • Mike M.
      • May 31, 1974
      • 8385
      clup: are you insinuating old gray haired flatus expellers are, after all, good for something? regards, mike
      • William C.
        • May 31, 1975
        • 6037
        Nope, just that pre-smog engine calibrations differ greatly from the later calibrations developed unde goverment mandates, and that any mechanic who has a whit of experience should know that.
        Bill Clupper #618
