C2: 63 Headlight Buckets - Primer - NCRS Discussion Boards
  • David Hicks
    I just got a chance to examine my headlights. I have a problem with one that has caused my paint to crack. In examining them I found that one has some damamge (causing the crack) and the other was replaced with metal. The damaged one looks like the original fibreglass, but it is hard to tell while still assembled. It looks like someone added custom brackets and them used the 64-67 bezels on both. Since under the crack is metalic looking I assumed it was metal too, but once I had the bezels off I realized they were two different buckets. The damaged one with the custom bracket job has the original screw holes front facing. Does anyone know if the primer would look metalic? The skin looks bonded to the inside bracket too. I am hoping this is the case, because I can always fix the fibreglass and then I just need to replace the metal one. Since I will be doing a complete repaint though and I want to wait to remove them til then, getting all the right parts lined up would help.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C2: 63 Headlight Buckets - Primer
    63s had fiberglass skinned headlite buckets and were primered just like the rest of the body. 64-67 used pot metal or some such metal and they were primered in a urine colored green,unlike the rest of the 64 to 67 body primer.Souinds like you need to sand the orig f-glass bucket to bare glass, evaluate the damage, repair if repairable.the metal one will have to be replaced for judging purposes. good luck mike
    • Wayne W.
      • April 30, 1982
      • 3605
      Re: C2: Urine Colored Green?
      First time I have heard of Zinc Chromate refered to as that. You know what us farm boys call 73 Yellow? Or any other color yellow for that matter. Calf T#$D Yellow. You will know what we mean if you have ever seen it.
      • Mike M.
        • May 31, 1974
        • 8396
        Wayne-us'en farm boys know what colostrum does when mixed with fresh mammary gland secretions yellow. Ain't you'ens ever seen green pee?. regards, mike
