I would like to attempt to adjust the valves on my '66 L72 as I think they need adjusting. I pulled the valve covers off to check the casting #'s and dates the other day & I noticed the rockers seem very loose to me. Maybe they don't need adjusting, but nonetheless I would like to learn how to do this.
Can someone please explain the proceedure in layman terms (as I not that mechanical). Another problem, is I have the battery & tray all out of the car now, so, can I do this by turning the motor over by hand, etc. and which way to turn the engine.
From what I've read, .024" intake, .028" exhaust when hot. Are these the best settings? And... what should the gap be if adjusted cold?
As usual, thank you for your help.
