C2: Radiator Question - NCRS Discussion Boards
  • David Hicks
    I have a 63 SWC with automatic trans that someone replace the 327 with a 350. In front of the radiator is a smaller core (somewhat chewed up, but there and still hooked up). I think this is the trans cooling core. Diagrams I have seen in various books leads me to believe it might be. Can someone confirm this for me.
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2: Radiator Question
    Most likely true. Follow the lines back and see where they go. Anything is possible----maybe one of the prior owners was pulling a trailer.
    Joe
    • Bob R.
      • June 30, 2002
      • 1595
      The 63 corvette with an automatic trans did have a small trans cooler mounted in front and at the base of the radiator. The hoses leaving the cooler should route through a small hole in the radiator suport just under the horn relay. They go just below your fuel pump to the transmission.
