C2: Powerglide ID - NCRS Discussion Boards
C2: Powerglide ID
  • David Hicks
    C2: Powerglide ID
    I was wondering if someone can help here. I received info on a powerglide trans, but the seller only gave me this info: 2 SP powerglide all alum case with the numbers 67 3863192 on the tail shaft. Anyone have any ideas what I am looking at here.
  • Warren S.
    • April 30, 1987
    • 100
    Re: C2: Powerglide ID
    David,
    My 67, which has it's original 2 speed powerglide transmission, has main case #3890504 and tail case #3864430. On the left side of the transmission oil pan you will find stamped numbers and letters, which will tell you the model year and built date. An example of my stamped numbers: "T7S14N" - T is for Toledo, 7 ia for model year, S14 is for Nov.14 built date, and N is for night shift.
