69 427 Conv. purchase help - NCRS Discussion Boards
  • Jack Corrao
    Hi all,
    Could anyone provide me with tips to authenticate a 427 car I am looking to purchase. It's a 390hp car with the correct hood, LM stamp and vin stamped on the block but no paperwork. It has been restored with new paint, interior, chrome but not undercarriage so there may be a tank sticker. The one discrepancy I see is that the tach has a 5800 yellow line and a 6000 redline. I am prety sure the 390 and 400hp cars had a 5600 redline. Should this be a cause for concern to look deeper or is it an oddball? How can I tell if the tach or the engine is not original to the car? I was hoping for some other ways of determining if this was a real 427 car or a "clone". Any underhood items not easily changed of fuel line sizes unique to a 390 car? It's not cheap so I am concerned that if I do drop the tank after I get it home and find a tank sticker it could be a let down. Should I use a Corvette appraiser/inspector?
    Thanks alot,
    Jack
  • Jerry Clark
    • Jack Corrao
      I have a photo of the engine stamping LM and VIN. I read in "Chevrolet by the numbers" that you can tell by the pattern left from the factory milling process can authenticate the stamping. Whereas if it were a restamp it would have been milled and left a different pattern. It appears to have a "moire" pattern as described. If anyone thinks they discern if the stamp is original by a photo email me and I will email it to you. This would pretty much tell me if its a real car.
      Thanks again,
      Jack
      • Jerry Clark
        "This would pretty much tell me if its a real car.
        Not by a country mile Jack
        • Craig S.
          • June 30, 1997
          • 2471
          Re: "This would pretty much tell me if its a real
          Jack - as Jerry states, there is a lot to look at to validate authenticity. However, you can compare the stamp to the photo I sent you of a 67 435 pad. The photo you sent me was not clear enough for me to tell if it is original. Best of luck!...Craig
          • Robert C.
            • December 1, 1993
            • 1153
            You should get someone that knows what to look for in your area. There are NCRS judges everywhere and for a fee will same you thousands! Call Roy Sinor , National Judging Chairman, for someone in your area. If you're in Dallas I'll do it.
