1960 top ignition shield - NCRS Discussion Boards
  • John M.
    • January 1, 1999
    • 1553
    Hey guys,
    I have looked till I am blue in the face for a correct top shield for my 60! I am looking for the short front skirt version with the cutouts on the passenger side. If anyone knows of a source or runs across one, I would appreciate a heads-up. The shield I am refering to is the second on from the top on page 415 in Nolan's book. I have been looking for a year and all I can find is the other styles.
    Regards, John McGraw
  • Calvin M.
    • August 31, 2000
    • 117
    Re: 1960 top ignition shield
    Hi John -
    Can you use 3730328 (3/60 thru '61)? My notes say I've got an NOS in the attic, and will look for you if it "fits".
    Cal
    • John M.
      • January 1, 1999
      • 1553
      Thanks Cal,
      Unfortunately my car is a January car. This is the way it has been going for the last year, Every one I run across is different then the one I need! The car is closing in on the 99% mark real close and points are only coming one at a time. This is one of those things that has allways bugged me, and sooner or later I will find a correct one.
      • Calvin M.
        • August 31, 2000
        • 117
        Hi John -
        Sorry mine won't work.
        One other long shot -- the Vintage section of Paragon's catalog shows a 3741865 as being (or at least at some point, was) available. Worth a call anyway, unless you already have. 800-882-4688. Good luck!
        Cal
