C1 Brakes - NCRS Discussion Boards
C1 Brakes
  • Edward D. Reich
    C1 Brakes
    Looking through my service guide, I cannot find anything on the procedure of bleeding brakes if there is one. Can anyone tell me if there is a procedure like starting with the left front first and going clockwise from there?? Some one said there was. Not sure.
    Thanks, Ed Reich
  • Ed Jennings
    Re: C1 Brakes
    I have always been led to believe one should start at the furthest point, ie right rear. I do it this way and have never experienced any difficulties.
    • Denny Jacobs
      Re: C1 Brakes
      The farthest point (at which to start) is actually the left rear (driver side).
      • Ed Jennings
        Re: C1 Brakes
        Hadn't thought about that, but you are absolutly correct; the line to the left side is quite a bit longer from the rear block. Apparently it doesn't make much difference since I've been doing it incorrectly for better than 35 years with good results!! I suspect that it is important to start at the rear though.
