C2 Master Brake Cylinder Numbers - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hello Everyone:
    Need some help regarding the numbers on my '66 manual brake master cylinder. The number 2225032 appears on the underside of the master cylinder which I believe to be correct. It is followed by what looks like 3 digits, ? a R or a B and then a 5.
    On the underside (LH side) were the cap clip snaps into place there is another cast number, 1 or I then a 03. (HArd to read backwards in a mirror)
    It the later two series of numbers I would like some help with.
    Thanks again to all.
    Kurt
  • Mark F.
    • March 1, 2002
    • 174
    Re: C2 Master Brake Cylinder Numbers
    Hi, Kurt:
    The markings on my '65 standard m/c are similiar to yours. I'm not sure what the significance of the numbers in the first part of your question is, but the R or B may be a Bendix logo.
    As to the numbers "103", I have been told that this is a julian day. This jives for the "239" on the bottom of my m/c, as the julian day converts to August 27, and the production date of my car is approximately September 4, 1964. Sources of information indicate that no '65-'66 m/c has ever been seen with a number here of greater than 365.
    Julian day of your m/c, if my advice is correct, would be April 13 if 1966 was a non-leap year, or April 12 if it was.
    Mark
    • R N.
      • May 31, 2002
      • 640
      Thank you for your reply Mark.
      Best regards,
      Kurt
