head casting numbers - NCRS Discussion Boards
  • Charles M.
    • March 1, 2002
    • 155
    What is the significance of the GM number (the 7 and 16) on my heads? Right side GM7 3782461, date A 5 6 .. Left side GM16 3890462, date D 11 6.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: head casting numbers
    I belive those numbers are the molds your heads came from at the foundry.
    Lyle
      Those are the foundry pattern numbers that the molds were made from; there were multiple sets of tooling for high-volume parts.
      • Charles M.
        • March 1, 2002
        • 155
        Here is the big question. Can I run these heads together? Are they similiar enough? If i have them ported can they be made equal?
        • Clem Z.
          • January 1, 2006
          • 9427
          go to www.google.com and type in the numbers+chevy head and you will get tons of info. just make sure the valves are the same size in both heads because these heads can with different size valves.
